12 years agoEDS Flash Programmer
So i’m using the new Cyclone V SoC in combination with NOR flash (Micron M25P80). I want to program the NOR flash via USB blaster -> Jtag -> HPS -> NOR flash. Therefor there is a program called So...
10 years ago --- Quote Start --- I get the same error trying to flash the QSPI. It worked the first time, and the "hello world" app comes up and runs. But now I can't erase or re-flash QSPI. Someone help! --- Quote End --- Did you try erase the qspi and redo again? I read the rocketboard there is some reset issue and precaution to take note in qspi boot up.
