12 years agoEDS Flash Programmer
So i’m using the new Cyclone V SoC in combination with NOR flash (Micron M25P80). I want to program the NOR flash via USB blaster -> Jtag -> HPS -> NOR flash. Therefor there is a program called So...
11 years agowell, you may need to stick to this work around for quite some time, as if this stable enough, you don't need to change it for no reason.
