12 years agoEDS Flash Programmer
So i’m using the new Cyclone V SoC in combination with NOR flash (Micron M25P80). I want to program the NOR flash via USB blaster -> Jtag -> HPS -> NOR flash. Therefor there is a program called So...
11 years ago --- Quote Start --- Hi, Unfortunately the device is not supported. Currently only the 1 Gbit is supported, I need the 2 Gbit. I have requested a service request from Altera, asking for the Quartus version where it will be supported, or a un-published option to ommit the ID check, or a patch. Will post Altera answer when they reply. I tried The programmer from Quartus 15.0 beta,still not supported. If I do not get any solution from Altera, the options are 1Gbit device or Use U-Boot to program the flash from DS5 debugger (Still have DDR3 8 and 16 bit memory problem (32 bit works fine) so this is not option now U-Boot fails) Thanks --- Quote End --- Hi, did you receive any feedback from Altera on this?
