12 years agoEDS Flash Programmer
So i’m using the new Cyclone V SoC in combination with NOR flash (Micron M25P80). I want to program the NOR flash via USB blaster -> Jtag -> HPS -> NOR flash. Therefor there is a program called So...
11 years ago --- Quote Start --- Hey, Programming of the NOR Flash trough JTAG with the "SoC EDS Command shell" Which you can download from the altera website. For this you need a NOR Flash that is supported by Altera. You can find the Supported Memory Devices in => "https://www.altera.com/en_US/pdfs/literature/ug/ug_soc_eds.pdf ",on page 196. If you have a Supported type, But still doesn't work. Check Your "BootSel settings" You can find the different settings => "https://www.altera.com/content/dam/altera-www/global/en_US/pdfs/literature/hb/cyclone-v/cv_5400a.pdf " , PAge 4 WARNING, i have bricked a NOR flash one time. I got the readback of 0xFFFFFFFF. After replacing the NOR chip (Be sure that it is a Supported Memory Devices) it worked again. For the 2Gbit with ID 22ba20. I had have contact with an application engineer from altera. Because, in the beginning i also used a different type (not Supported by altera). But i don't think they will give the source code for the EDS tool. And i also think that altera won't support other devices in the near future. So my advice would be, replace it. And if you want more Flash memory, Get a SLC NAND Or e.MMC NAND chip on there. Cheers, HidTec --- Quote End --- Hi, Unfortunately the device is not supported. Currently only the 1 Gbit is supported, I need the 2 Gbit. I have requested a service request from Altera, asking for the Quartus version where it will be supported, or a un-published option to ommit the ID check, or a patch. Will post Altera answer when they reply. I tried The programmer from Quartus 15.0 beta,still not supported. If I do not get any solution from Altera, the options are 1Gbit device or Use U-Boot to program the flash from DS5 debugger (Still have DDR3 8 and 16 bit memory problem (32 bit works fine) so this is not option now U-Boot fails) Thanks
