12 years agoEDS Flash Programmer
So i’m using the new Cyclone V SoC in combination with NOR flash (Micron M25P80). I want to program the NOR flash via USB blaster -> Jtag -> HPS -> NOR flash. Therefor there is a program called So...
12 years agoI have a similar problem.
Flash can not be read after the wrong programming It is possible to correct the mistake? --- Quote Start --- Current hardware is: USB-Blaster [USB-1] Found HPS at device 1 HPS Device IDCODE: 0x4BA00477 AHB Port is located at port 0 APB Port is located at port 1 Boot Info: 3.0V QSPI Flash Start HPS Quad SPI flash programming ... Initialize QSPI peripheral and flash controller ... Read Silicon ID of Quad SPI flash ... Quad SPI Flash silicon ID is 0xFFFFFFFF Error: Not able to map flash ID from flash database Error: Quartus II 32-bit Programmer was unsuccessful. 0 errors, 0 warnings Error: Peak virtual memory: 102 megabytes Error: Processing ended: Thu Sep 18 14:03:44 2014 Error: Elapsed time: 00:00:02 Error: Total CPU time (on all processors): 00:00:00 --- Quote End ---
