UnixDev
9 months agoeCoS OS throws execption when freeing memory
We have a firmware applicaiton that makes use of eCoS RtoS and NIOSII core. We have a logic that we first allocate memory dynamically and then if required delete the previous allocated memory and all...
Sparrow_Altera
8 months agoYou may have a possible heap corruption based on the stack trace. The fact that the allocation just before this succeeds, but free dies, fits with heap corruption: malloc didn’t happen to touch the damaged area; free did. Heap metadata is corrupted or the pointer/size you’re freeing is not consistent with how it was allocated.
Things you can check:
- Size mismatch between alloc and free: Confirm that the size used for allocation and the size passed into vf_free_buffer() are always identical.
- Buffer overrun/underrun before the 7th free: If bytes_to_copy exceeds either the old or new allocation size, you write -> That trashes the allocator’s metadata. dlmalloc stores control info just before/after the user block; once that’s corrupted, the next free() can blow up. Check all memcpy, memmove, memset, and loops that touch this buffer.
- Double free or freeing a modified pointer: After vf_free_buffer(), always set the pointer to NULL. Make sure there’s a single owner of this buffer; no multiple modules freeing it.
- Using the buffer after freeing: If your “resize until bigger” logic lives in this area, it’s easy to do: Allocate buffer, Use buffer, Decide you need a bigger buffer → allocate new, free old. But something still holds a pointer to the old buffer and writes into it while or after it’s freed. This again corrupts heap metadata, shows up in a later free(). Ensure that all users of the buffer go through a single handle. Whenever you resize, update that handle everywhere before any further writes.
- Memory layout / stack overlap: If stack or some other buffer overwrites the heap region around 0x017136A0, dlmalloc will die on free.
As a sanity check: Temporarily skip resizing logic
- Change the code to allocate a large enough buffer once, then use it without freeing/resizing in the loop.
- Keep all the same write/copy logic.
If the exception disappears:
- The problem is very likely tied to how you’re managing allocations (size mismatch/double free).
If the exception still occurs:
- The bug is almost certainly a pure buffer overrun/underrun in your write logic, independent of malloc/free.
