15 years agoeCos lib tree building mounting problems
Hallo everyone! I have a little, but strange problem: I installed Altera Quartus II and Nios II v5.1 onto my computer (Windows XP Professional SP3). I installed an ecos to it. I start the com...
15 years agoI have a workaround. Before ecosconfig.exe I call mount -tf c:\\ /ecos-c commands, and after ecosconfig.exe is done I call umount c:
With this workaround I recieve other errors: headers finishednios2-elf-gcc: /ecos-c/altera/kits/nios2_51/components/ecos/ecos-current/packages/hal/nios2/arch/current/src/gtf-launch.in: no such file or directory
nios2-elf-gcc: warning: `-x c' after last input file has no effect
nios2-elf-gcc: no input files
make[3]: *** [/ecos-c/source/embedded/nios/project/software/project_ecoslib/debug/project_install/gtf-launch] error 1
make[2]: *** [build] error 2
make[1]: *** [/cygdrive/c/source/embedded/nios/project/software/project_ecoslib/debug/project_install/lib/libtarget.a] error 2 I looked up manually for this gtf-launch.in file at c:\altera\kits\nios2_51\components\ecos\ecos-current\packages\hal\nios2\arch\current\src and found it. I can open, write and edit it. Why could I receive that problem?
