15 years agoeCos lib tree building mounting problems
Hallo everyone! I have a little, but strange problem: I installed Altera Quartus II and Nios II v5.1 onto my computer (Windows XP Professional SP3). I installed an ecos to it. I start the com...
15 years agoI tried it. The output is as follow in that case (with ECOS_REPOSITORY environment variable as unix-style given):
c:\altera\kits\nios2_5114.06.2011 07:07:55 - (schwerwiegend) generate: java.lang.illegalstateexception: java.io.filenotfoundexception: c:\altera\quartus51\bin\cygwin\cycdrive\c\altera\kits\nios2_51\components\ecos\ecos-current\packages\hal\nios2\arch\current\gtf\nios2_auto.cdl.gtf (das system kann den angegebenen pfad nicht finden)
parameters for ecosconfig --prefix=/cygdrive/c/source/embedded/nios/project/software/project_ecoslib/debug/project_install --config=/cygdrive/c/source/embedded/nios/project/software/project_ecoslib/project_debug.ecc tree
ecos.db: error
couldn't read file "c:/cycdrive/c/altera/kits/nios2_51/components/ecos/ecos-current/packages/ecos.db": no such file or directory
invalid package database.
