15 years agoeCos lib tree building mounting problems
Hallo everyone! I have a little, but strange problem: I installed Altera Quartus II and Nios II v5.1 onto my computer (Windows XP Professional SP3). I installed an ecos to it. I start the com...
15 years agoAt first I tried the /cygwin/c/ variant. In that case I get the following error(s):
c:/altera/kits/nios2_51/components/ecos/ecos-current/packages/hal/nios2/arch/current/cdl/hal_nios2.cdl: errorthe file c:\dokume~1\andras~1\lokale~1\temp/nios2_auto.cdl does not exist.
this file is normally created by either the
nios2configtool or nios2ecosconfig wrapper scripts: > nios2configtool --ptf=<ptf file> --cpu=<cpu name> or: > nios2ecosconfig --ptf=<ptf file> --cpu=<cpu name> alteratively, you can generate it directly before
starting the configuration tool: > gtf-generate --gtf=$ecos_repository/hal/nios2/arch/current/gtf/nios2_auto.cdl.gtf --ptf=<ptf file> --cpu=<cpu name>
u cygbld_iso_ctype_header, new inferred value <cyg/libc/i18n/ctype.inl>
u cygbld_iso_errno_codes_header, new inferred value <cyg/error/codes.h>
u cygbld_iso_errno_header, new inferred value <cyg/error/errno.h>
u cygbld_iso_stdio_filetypes_header, new inferred value <cyg/libc/stdio/stdio.h>
u cygbld_iso_strerror_header, new inferred value <cyg/error/strerror.h>
u cygbld_iso_strtok_r_header, new inferred value <cyg/libc/string/string.h>
u cygbld_iso_string_locale_funcs_header, new inferred value <cyg/libc/string/string.h>
u cygbld_iso_stdlib_strconv_header, new inferred value <cyg/libc/stdlib/atox.inl>
u cygbld_iso_stdio_streams_header, new inferred value <cyg/libc/stdio/stdio.h>
u cygbld_iso_stdio_fileops_header, new inferred value <cyg/libc/stdio/stdio.h>
u cygbld_iso_stdio_fileaccess_header, new inferred value <cyg/libc/stdio/stdio.h>
u cygbld_iso_stdio_formatted_io_header, new inferred value <cyg/libc/stdio/stdio.h>
u cygbld_iso_stdio_char_io_header, new inferred value <cyg/libc/stdio/stdio.h>
u cygbld_iso_stdio_direct_io_header, new inferred value <cyg/libc/stdio/stdio.h>
u cygbld_iso_stdio_filepos_header, new inferred value <cyg/libc/stdio/stdio.h>
u cygbld_iso_stdio_error_header, new inferred value <cyg/libc/stdio/stdio.h>
u cygbld_iso_stdlib_abs_header, new inferred value <cyg/libc/stdlib/abs.inl>
u cygbld_iso_stdlib_div_header, new inferred value <cyg/libc/stdlib/div.inl>
u cygbld_iso_string_bsd_funcs_header, new inferred value <cyg/libc/string/bsdstring.h>
u cygbld_iso_string_memfuncs_header, new inferred value <cyg/libc/string/string.h>
u cygbld_iso_string_strfuncs_header, new inferred value <cyg/libc/string/string.h>
u cygbld_iso_setjmp_header, new inferred value <cyg/libc/setjmp/setjmp.h>
u cygbld_iso_c_time_types_header, new inferred value <cyg/libc/time/time.h>
u cygbld_iso_c_clock_funcs_header, new inferred value <cyg/libc/time/time.h>
u cygbld_iso_dirent_header, new inferred value <cyg/fileio/dirent.h>
u cygbld_iso_bsdtypes_header, new inferred value <sys/bsdtypes.h>
u cygbld_iso_open_max_header, new inferred value <cyg/fileio/limits.h>
u cygbld_iso_name_max_header, new inferred value <cyg/fileio/limits.h>
u cygbld_iso_netdb_proto_header, new inferred value <net/netdb.h>
u cygbld_iso_netdb_serv_header, new inferred value <net/netdb.h>
unable to open file c:\source\embedded\nios\project\software\project_ecoslib\project_debug.ecc
package cygpkg_hal_nios2, 1 error occurred while reading in the cdl data.couldn't open "c:\source\embedded\nios\project\software\project_ecosib\project_debug.ecc": permission denied
