12 years agoeCos interrupts (PIE in status register =0)
Hi all,
my (timer) interrupt didn't work until I figured out, that bit 0 (PIE) in the status register is set to 0. So after all of my initialization stuff is done, I set that bit to 1. The system works, however any program interruption through gdb frontend is end of story - gdb frontend says "trap" and can't find the proper breakpoint address then. It is quite possible that I something messed up, as during investigation of the problem I added some assembly to eCos HAL (LED blinking in vectors.S). My solution is rather hack so my question is, is there a _clean_ way to enable global interrupts on eCos? Note that I use eCos from github & zylin howto. Thanks, Michal
