16 years agoEclipse: Project Conversion Failed
I am trying to load a project from the Terasic DE2 CD from Eclipse IDE in NIOS 10. When I select the workspace the following message shows: "project conversion failed for project hello_l...
15 years agoWell, we tried that but since we can't even build the project (we are using the DE2_NET example), we don't have a Build or Release folder so the console outputs the error "Not a valid input directory" after trying to convert it using that console command.
What is the problem and what can we do now??
