16 years agoEclipse: Project Conversion Failed
I am trying to load a project from the Terasic DE2 CD from Eclipse IDE in NIOS 10. When I select the workspace the following message shows: "project conversion failed for project hello_l...
15 years agoYou need to convert the IDE project which is _syslib to Eclipse format which is _bsp in command line, after that import the project to Nios II SBT for Eclipse.
