Anu_Jayan
3 years agoEclipse IDE is not opening
HI
I am using Ubuntu 20.04.4
1) I have installed Intel Quartus Prime Pro edition 20.1.0.
2) Then followed the below link for installing the Eclipse IDE into Nios II EDS.
https://www.terasi...
- 3 years ago
Attached here is a screenshot of the supported Ubuntu OS for the Quartus version 20.4pro that you are using.
As it does not support 20.04, you may have to upgrade the Quartus version.
Thank you.
Kelly
KellyJialin_Goh
3 years agoHi,
I just checked for the Quartus version 20.1 pro that you are using, it does not support Ubuntu OS 20.04.
You may have to upgrade to a newer Quartus version, which is 20.4pro onwards that supports the Ubuntu OS that you are using.
Once you have upgraded the Quartus version and perform the steps from the previous link on Linux Installation, the errors should be eliminated.
Hope to hear on your feedback.
Thank you.
Kelly
