Eclipse IDE is not opening
- 3 years ago
Attached here is a screenshot of the supported Ubuntu OS for the Quartus version 20.4pro that you are using.
As it does not support 20.04, you may have to upgrade the Quartus version.
Thank you.
Kelly
Hi Kelly
I have tried the above installation procedure, but still I am not able to open Eclipse IDE. I tried opening sudo ./eclipse-nios2.exe. But I got error as below.
An error occurred see the log file /root/.altera.sbt4e/20.1.0.177-linux64/configuration/1682516664296.log
Below I have attached the log of the error
!SESSION 2023-04-26 19:14:24.070 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_232
java.vendor=AdoptOpenJDK
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_IN
Framework arguments: -product org.eclipse.epp.package.cpp.product -pluginCustomization /home/zumi/intelFPGA_pro/nios2eds/bin/eclipse_nios2/plugin_customization.ini
Command-line arguments: -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.cpp.product -pluginCustomization /home/zumi/intelFPGA_pro/nios2eds/bin/eclipse_nios2/plugin_customization.ini
!ENTRY org.eclipse.osgi 4 0 2023-04-26 19:14:24.529
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:78)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
Anu Jayan
