15 years agoDual port shared memory
Hi! I am working on a project which includes NIOS as the main host processor and it has other parts designed in verilog (a transceiver, a control unit). In the project a dual port memory is to ...
15 years ago --- Quote Start --- I have tried to import my design file to SOPC builder, the snapshot is attached, I'd appreciate if you can have a look and tell me if there are any errors. Secondly, how can I access this custom built design while programming. The imported design in this case is a memory, which has to be written to through a DMA. Can you please give me some example, (a macro may be) about how to write to this memory. Thanks --- Quote End --- The error is about the clock assosiation. In the interface tab, just select the clock associated with the avalon_0 interface. See the snapshot. I can't help you with the programming. I'm a hardware designer and let others do the programming :) Success, Ton
