14 years agoDual port memory corruption
We have system that is using an M9K memory block for IPC between two nios2 cpus. CPU A accesses it as tightly coupled data memory, CPU B via the data port and Avalon bus (no data cache on eithe...
13 years agoWith SOPC Builder you will get clock crossing adapters and width adapters per master:slave pairing when they are needed. Clock crossing adapters can be spotted during generation time since you'll see messages like "clock_0" flying by the screen for each one. Finding the width adaptation logic is not so easy.
So from the way you described the system assuming you only have the second Nios II data master and PCIe master hooked up to the second port of the on-chip RAM, I would only expect one clock crossing and one width adapter to be placed between the PCIe and memory cores. Not related to the problem but one thing you probably want to avoid is the additional bursting from the PCIe through the clock crossing adapter into the memory. Those automatic clock crossing adapters only let one beat through at a time and each takes a few clock cycles to make their way through. The clock crossing bridge will do a better job because the data crosses domains using FIFOs so you can fill the FIFO with a rate of one beat/clock cycle assuming there is room in the FIFO. All of this is starting to jog my memory, I can't believe I managed to find this but you could be running into this: http://www.altera.com/support/kdb/solutions/rd11022009_41.html I think the PCIe core performs bursts of 32 beats. So what you could do is setup a clock crossing bridge to be the width of the PCIe master and non-bursting. Place the clock crossing bridge between the PCIe core and the memory. What this will do is force the burst adapter to be placed between the bridge and PCIe core, and the width adaptation between the bridge and the memory. Place the clock crossing bridge master on the same domain as your CPUs and memory, and the bridge slave should be on the same domain as the PCIe master.
