14 years agoDual port memory corruption
We have system that is using an M9K memory block for IPC between two nios2 cpus. CPU A accesses it as tightly coupled data memory, CPU B via the data port and Avalon bus (no data cache on eithe...
14 years agoThat's supposed to work with M9K blocks. Do you have the 2nd port running on a difference clock frequency or have the latency set two 2 cycles by any chance? I wouldn't expect either to be a problem but it might be something to check out if that's the case.
The behavior you are seeing sounds more like a timing problem to me, especially if you have the read latency set to 1 on the 2nd port. With a read latency of 1, the output of the RAM is not registered and perhaps CPU 2 reading the data is not seeing a settled copy of the data. If this is happening then the timing report should be flagging this as a violation (assuming the constraints are setup properly). Speaking of proper constraints.... I forget which version of the tools had this problem, but there was a bug that caused data corruption in the on-chip memories due to an incorrect timing constraint being made. I can't remember if it was 11.0 or 11.1 that had that issue but if you are using Quartus II without service packs you might want to grab a SP since that issue could result in what you are seeing.
