15 years agoDual NIOS exception overwrite
When I load the second NIOS code, it overwrites the exception handler in the first NIOS space. I'm using a shared ddr_sdram, but neither core's linker maps overlap. Exception addresses are 08000...
15 years agowell I don't think I'd be able to help, but if I were you I'd start looking to see what is causing the problem by:
- Would the same address range be overwritten if there was only one processor in the system? - Is the address being overwritten in fact the same as the other Nios's ISR? I'd check this by changing the Nios's base address. - Would it matter that you load the Nios that has the higher address (09X...) first, then the other one? Cheers, Kaveh
