10 years agoDTB i've created from .sopcinfo --> doesn't work
Hi All,
I'm working on a custom board - assembly with arria5 device ( booting linux from QSPI ). Linux is running if i using socfpga_arria5_socdk.dtb ( from : arch/arm/boot/dts/ ) - original of EVB. If I using my DTB ( from sopcinfo ) - the linux doesn't run , it stuck on "starting kernel" . My convert process: - Converting the .sopcinfo ( from my QSYS poject ) to DTS using sopc2dts.exe tool. - Changing console from ttyAL0 to ttyS0 in the DTS. - Copy the DTS to my kernel's DTS folder (change the name to socfpga_arria5_socdk.dts ) - Run "make ARCH = arm dtbs" please advise how should i convert/use .sopcinfo file. Thanks in advanced, Moran.No RepliesBe the first to reply
