13 years agoDS-5 unable to connect (C5-SoC). FLEXnet Licensing error: -88
Hello, I have recently attended to a SoCKit workshop to have the first contact with the Cyclone V SoC architecture. Some days later I tried to go again through the steps of the hands-on to be a...
13 years agoI set the problem aside some time but finally I got to solve it. This FLEXnet is an utility which monitores if a certain licensed program is running under a clean PC. That means that it will catch some common "tricks" to evade the licenses limitations and avoid any licensed program to run in such a machine.
In my case, it detected that I had a file modified after the actual date. It interpreted thus that I had changed the date of the machine and that I could be trying to abuse the license. I could not solve this problem without a format of the whole machine. In my case, the conflictive file was something inside my TINA-TI installation which I did not modify myself and had a creation data in 2017. Just removing it and reinstalling the whole Altera software did not help.
