10 years agoDS-5 license generation
I notice there is an option to generate the ultimate ds-5 license for 30 days, I was using this for weeks, too bad that accidentally delete the license, but when I tried to generate this again, the ...
10 years agoHello, i am also using evaluation before, did you try manually add the file by locate it back to the folder?
Licenses are searched for in the following locations: ARMLMD_LICENSE_FILE environment variable: "C:\Users\samx\AppData\Roaming\ARM\DS-5\licenses" LM_LICENSE_FILE environment variable: not set DS-5 licenses directory: "C:\Users\samx\AppData\Roaming\ARM\DS-5\licenses"
