16 years agodriver module nios2linux nommu
nios2linux
nommu altera de2 2c35 de2_net.sof, de2_net.ptf Ok i am trying to write an driver module with ioctl interface to access to leds. (For example). Under Kernel Settings i did: [*] Enable loadable module support ---> [*] Module unloading Here is my driver module:# include <linux/module.h># include <linux/init.h> # include <linux/kernel.h># include <linux/fs.h>
MODULE_AUTHOR("xxx");
MODULE_LICENSE("GPL");
MODULE_DESCRIPTION("xxx");
MODULE_SUPPORTED_DEVICE("none");
# define driverMAJOR (250)
int led_ioctl (struct inode *inode, struct file *file, unsigned int var1, unsigned long var2)
//nothing here ... just testing
return 0;
static struct file_operations fops = {
.owner = THIS_MODULE,
.ioctl = led_ioctl,
static int __init led_init(void)
int retval = -1;
retval = register_chrdev(driverMAJOR, "led", &fops);
if (retval<0) printk("Cannot register led device!\n");
else
printk("Device registered!\n");
return 0;
static void __exit led_exit(void)
unregister_chrdev(driverMAJOR, "led");
return;
module_init( led_init );
module_exit( led_exit );
with nios2-terminal i say: mknod /dev/led c 250 0 insmod led.ko Everything looks ok. Here is my userland program: # include <stdio.h># include <sys/types.h># include <sys/stat.h># include <fcntl.h># include <stdio.h># include <unistd.h># include <sys/mman.h>
int main (void)
int fd = open("/dev/led", O_RDWR);
//nothing here
return 0;
} As soon as i execute it, the board reboots ... nios2-terminal gives a lot of cryptic signs and thats it. I am stuck, any tips?No RepliesBe the first to reply
