10 years agoDownloading ELF process failed while using the external memory present in the board
Hi, I'm using the BeMicro Kit and I'm using the external 8MB RAM present in the board. I've added the SDRAM controller in the Qsys along with the NIOS II/e processor and it compiled successfull...
JMuri1
6 years agoHi,
I found out that I had not moved one of the keys on my MAX 10 board up to the correct position. By moving key 9 to the up position Nios II was able to upload the ELF file without a problem. There was no problem with the card.
/James
