10 years agoDownloading ELF process failed while using the external memory present in the board
Hi, I'm using the BeMicro Kit and I'm using the external 8MB RAM present in the board. I've added the SDRAM controller in the Qsys along with the NIOS II/e processor and it compiled successfull...
10 years agoIt looks like your memory isn't working. To confirm this, run a memory test on the external ram. You've covered up the addresses. Make sure they are correct.
