10 years agoDownloading ELF process failed. Connected system ID is also not found.
Hello, I'm using Altera 15.1.0.185 Lite Edition software to do a simple project using MAX10 FPGA, which consists of NIOS II Processor, on chip memory and Jtag UART in Qsys. Compilation is suc...
10 years ago --- Quote Start --- Just to check, but are you sure that your Nios2 system is really being instantiated on the top-level module of the design ? This could explain the inexistence of any ID loaded at the physical target. --- Quote End --- Nios II has been instantiated in top module. same project is running in others system without any error and the output exists in NIOS II console also.
