10 years agoDownloading ELF process failed. Connected system ID is also not found.
Hello, I'm using Altera 15.1.0.185 Lite Edition software to do a simple project using MAX10 FPGA, which consists of NIOS II Processor, on chip memory and Jtag UART in Qsys. Compilation is suc...
10 years agoYou are getting a file not found error for your elf file. Check that the file is there. If it isn't, look at the error messages you get when building. Check that full file permissions to write to the directory where your project is.
