10 years agoDownloading elf error from nios2 command shell...
I am using Quartus 14.0 and Cyclone V FPGA..... In Qsys system integration tool i am using NOR flash base address as a Reset vector and SDRAM base address as a Exception vector. If i try to...
10 years agoHello Sagar,
You can try using -r command which is used to reset processor. ( I mean you can use following command while using Nios II command shell : nios2-download -g -r ~/uart_with_fpp.elf ) I request you to post result once you try this. Regards, Bhaumik
