10 years agoDownloading elf error from nios2 command shell...
I am using Quartus 14.0 and Cyclone V FPGA..... In Qsys system integration tool i am using NOR flash base address as a Reset vector and SDRAM base address as a Exception vector. If i try to...
10 years agoHello Sagar,
Your error message says USB-Blaster[2-2]. See number 2-2. It seems to me that there are 2 USB Blasters connected on your system. Is this correct? If yes, while you download your image using IDE, which USB blaster do you select? Regards, Bhaumik
