11 years agoDownload Elf Process failed
i am working on cyclone V soc (5csxfc6d6f31c8) and using nios II as processor. i have generated sof and sopcinfo and also programmed the device successfully. But after configuring the nios and generating the .elf this error pops up - Downloading Elf Process failed In the Eclipse Console window I get the following lines: Using cable "USB-BlasterII [USB-1]", device 2, instance 0x00 Resetting and pausing target processor: FAILED Leaving target processor paused i have read many posts relating to this but i am not able to figure out the actual issue. Please help me with this asap. Thanks in advance.12 Replies
could you please also post your *.sdc-file?
--- Quote Start --- could you please also post your *.sdc-file? --- Quote End --- sdc file contains these statements only - https://www.alteraforum.com/forum/attachment.php?attachmentid=10156
