10 years agodownload elf file failed. verify failded address...
i am rather new and following the hello world tutorial. everything goes well until I try to run the hello world project on board. I cannot download the elf to the board .I am using the on-chip memory...
10 years ago --- Quote Start --- ok. it seems it's the capacity problem. I create the new project with small hello world template and it goes further, but stop here Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Processor is already paused Initializing CPU cache (if present) OK Downloading 00008000 ( 0%) Downloading 000082D8 (98%) Downloaded 1KB in 0.0s Verifying 00008000 ( 0%) Verifying 000082D8 (98%) Verified OK Starting processor at address 0x00008020 doesn't show the hello world in NIOS II console help looooooooooooooool --- Quote End --- Hi, Is this problem got resolved?? Even I am facing the same issue. Does not show hello world in NIOS console. And even I added a logic to blink the LEDs, even that dint not work..
