dos2unix fails to change permissions when creating project from template
- 5 years ago
I also ran into this problem. I did some debugging and the problem is that the dos2unix command tries to change the UNIX filesystem permissions of the temporary file it creates; this fails for me in WSL.
You need to tell WSL that it should allow these kinds of operations on the filesystem. You can do this as follows:
- Start your Ubuntu 18.04 LTS prompt
- Create/edit a file '/etc/wsl.conf'
- Add the following to '/etc/wsl.conf':
[automount] options = "metadata" - Save the file.
- Reboot your computer.
I have no idea why this works for some people but not others, but this worked for me and fixed the dos2unix permissions error; at which points I was able to create the BSP and everything else in Nios II EDS worked fine.
Hello @juschri Justin,
First of all, thank you for reaching us,
Please try the next KDB (Knowledge DataBase) and let me know who it worked and if you have any questions please do not hesitate to let me know.
-Eliath Guzman
Hi Eliath,
I see it has been 2 months since you replied to Justin's question but I don't see a solution. Have you found one? I have this issue with Quartus lite v20.
- NickWilliams5 years ago
- jim121385 years ago
Can you please provide how you did it? Is it in the command line? I can't seem to find anything
- juschri5 years ago
@NickWilliams solution worked for me. I followed the instructions on
https://ajeet.dev/how-to-use-windows-subsystem-for-linux/
to create the wsl.conf file. The exact steps I took were:
From within Ubuntu 18.04 LTS (which I already had installed for Windows Subsystem for Linux) I executed the command
explorer.exe .
In the explorer window that opened I went up 2 directories to Ubuntu-18.04
Next I opened the etc directory and created a new file titled "wsl.conf"
Next I opened this with a text editor and edited it to say
[automount]
options = "metadata"as per @NickWilliams suggestion.
I saved this file, then restarted my computer.
After restart I reopened my project in quartus, used the tools menu to open "Nios II Software Build Tools for Eclipse" Then following the instructions in the lab tutorial Eclipse was finally able to create my project without errors.
