15 years agoDo I need to set compile flag for Hardware Floating Point Custom Instruction Divider?
I added the hardware FPU into SOPC including divider. In the public.mk file the compile flag is: ALT_CFLAGS += -mcustom-fpu-cfg=60-1 ALT_LDFLAGS += -mcustom-fpu-cfg=60-1 So I have to set ...
15 years agoI've just look at the gcc sources and done some quick tests (gcc3).
Setting -mcustom-cpu-cfg=60-2 or 73-2 does cause a custom instruction to be generated for divide, 60-1 doesn't. Adding -mcustom-fdivs=nnn is also enough.
