17 years ago
DMA transfer called from PIO ISR
I want to test DMA transfer from memory to memory. I tried to use MemTest example design to do it. Everything is ok when I call this funcion once - in main(). But when I try to trigger DMA transfer from PIO ISR - nothing happens. It looks like PIO ISR is not even called, because I can't see a text which should appear or flashing LED. When I comment the line where DMA transfer function is called, everything works (everything but DMA of course).
MemDMATest - does dma transfer
dma_done - dma irq isr
handle_button_interrupts - PIO irq isr
init_button_pio - registers and configures PIO irq
Here is my code:
<div class='codetop'>CODE</div><div class='codemain' style='height:200px;white-space:pre;overflow:auto'># include <stdio.h># include <alt_types.h># include <io.h># include <string.h># include "altera_avalon_pio_regs.h"# include "sys/alt_irq.h"# include "system.h"# include "sys/alt_dma.h"# include "sys/alt_cache.h"# include "alt_types.h"# include "io.h"
volatile int edge_capture;
volatile int led=1;
# define src (volatile char*) 0x02101100# define target (volatile char*) 0x02101080
static volatile int rx_done = 0;
static volatile int rx_done_bak = 0;
static void dma_done (void* handle, void* data)
rx_done_bak++;
rx_done=rx_done_bak;
static int MemDMATest(unsigned int memory_base)
int rc;
alt_dma_txchan txchan;
alt_dma_rxchan rxchan;
if ((txchan = alt_dma_txchan_open("/dev/dma")) == NULL)
exit (1);
printf("TXCHAN opened...");
if ((rxchan = alt_dma_rxchan_open("/dev/dma")) == NULL)
exit (1);
if ((rc = alt_dma_txchan_send (txchan, src, 4, NULL,
NULL)) < 0)
exit (1);
if ((rc = alt_dma_rxchan_prepare (rxchan, target, 4,
(alt_rxchan_done*)dma_done, NULL)) < 0)
exit (1);
while (!rx_done);
rx_done = 0;
alt_dma_txchan_close(txchan);
alt_dma_rxchan_close(rxchan);
return 0;
static void handle_button_interrupts(void* context, alt_u32 id)
/* cast the context pointer to an integer pointer. */
volatile int* edge_capture_ptr = (volatile int*) context;
* Read the edge capture register on the button PIO.
* Store value.
if(led==1) led=0; else led=1;
IOWR_32DIRECT(LEDS_PIO_BASE,0,led);
*edge_capture_ptr =
IORD_ALTERA_AVALON_PIO_EDGE_CAP(BUTTONS_PIO_BASE);
/* Write to the edge capture register to reset it. */
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(BUTTONS_PIO_BASE, 0);
/* reset interrupt capability for the Button PIO. */
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(BUTTONS_PIO_BASE, 0xf);
usleep(500000);
printf("Start");
MemDMATest(SRAM_16BIT_512K_0_BASE);
printf("Test: OK");
static void init_button_pio()
/* Recast the edge_capture pointer to match the
alt_irq_register() function prototype. */
void* edge_capture_ptr = (void*) &edge_capture;
/* Enable all 4 button interrupts. */
/* Reset the edge capture register. */
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(BUTTONS_PIO_BASE, 0x0);
/* Register the ISR. */
alt_irq_register( BUTTONS_PIO_IRQ,
edge_capture_ptr,
handle_button_interrupts );
int main()
printf("Start...\n");
init_button_pio();
while(1);
return 0;
}</div>
1 Reply
    OK.I have my problem resolved by re-enabling interrupt in the PIO ISR... using alt_irq_enable_all().
