20 years ago
dma and lan91 test problem
int alt_avalon_lan91c111_output(alt_avalon_lan91c111_if *dev, void *buffer, alt_u32 length)
alt_u8 irq_value;
alt_u16 mmu_status;
alt_u32 remainder;
alt_u32 len = length;
alt_u8 buffer1[200];
void *buf =(void *) buffer;
void *test;
alt_dma_txchan txchan;
int tx,i,k;
buffer1[0]=0x10;
buffer1[1]=0x11;
buffer1[2]=0x12;
buffer1[3]=0x13;
buffer1[4]=0x14;
buffer1[5]=0x15;
IOWR_32DIRECT(0x1055248, 0, 0x87654321);
/* Wait for the last Tx to complete */
do
irq_value = IORD_ALTERA_AVALON_LAN91C111_IST(dev->base_addr);
}while(!(irq_value & ALTERA_AVALON_LAN91C111_INT_TX_EMPTY_INT_MSK));
/* Clear the interrupt */
IOWR_ALTERA_AVALON_LAN91C111_ACK( dev->base_addr,
ALTERA_AVALON_LAN91C111_INT_TX_EMPTY_INT_MSK);
/* Always re-use the same packet */
IOWR_ALTERA_AVALON_LAN91C111_PNR( dev->base_addr,
dev->tx_packet_no);
IOWR_ALTERA_AVALON_LAN91C111_PTR( dev->base_addr,
ALTERA_AVALON_LAN91C111_PTR_AUTO_INCR_MSK);
/* The status word */
IOWR_ALTERA_AVALON_LAN91C111_DATA_HW( dev->base_addr, 0);
* The byte count including the 6 control bytes
* Bit odd this, but the length is always written as even, if the frame is an odd length
* then the byte is written as one of the control words and an appropriate bit is set
IOWR_ALTERA_AVALON_LAN91C111_DATA_HW( dev->base_addr, ((length & ~1) + 6));
* Write buffer of data to the device
* Nios requires accesses to be aligned on the correct boundary
while ((int)buf & 3)
IOWR_ALTERA_AVALON_LAN91C111_DATA_BYTE( dev->base_addr, *((alt_u8*)buf)++);
len--;
remainder = len & 3;
/* Write out the 32 bit values */
len>>=2;
if (len < 186){
while (len & ~7) /* Write 8-tuples of 32 bit values */
IOWR_ALTERA_AVALON_LAN91C111_DATA_WORD( dev->base_addr, *((alt_u32*)buf)++);
len-=8;
while (len)
len--;
}else{
test = buf;
for(i=0; i<= 200; i+=1)
printf("00:%x,%x\n",((alt_u32*)test)+i,*((alt_u32*)test+i));
if ((txchan = alt_dma_txchan_open("/dev/dma")) == NULL)
exit (1);
//printf ("0: %d,%d,%d\n",remainder,(alt_u8*)buf,*(alt_u8*)buf);
printf ("0: %d,%d,%d\n",len*4,(alt_u8*)buf,*(alt_u8*)buf);
alt_dma_rxchan_ioctl (txchan,0x3, dev->base_addr+8);
alt_dma_rxchan_ioctl (txchan,0x7, dev->base_addr+8);
if ((tx = alt_dma_txchan_send (txchan,buf,len*4,dma_tx,NULL)) < 0)
printf ("1: %d\n", tx);
exit(1);
while (!tx_done);
//printf ("2: %d\n", tx);
(alt_u8*)buf=(alt_u8*)buf+len*4;
IOWR_ALTERA_AVALON_LAN91C111_PTR( dev->base_addr,0x6000);
for(i=0; i<= 800; i+=4)
k = IORD_32DIRECT(dev->base_addr,8);
printf("%x\n",k);
//printf ("2: %d,%d,%d\n",remainder,(alt_u8*)buf,*(alt_u8*)buf);
printf ("2: %d,%d,%d\n",len*4,(alt_u8*)buf,*(alt_u8*)buf);
alt_dma_txchan_close (txchan);
len = 0;
tx_done = 0;
while (remainder)
remainder--;
if (length & 1)
ALTERA_AVALON_LAN91C111_CONTROL_ODD_MSK);
else
* Accesses to the MMUCR have to be protected with a semaphore as it&#39;s possible
* that we could wait for this register not to be busy and in between our read
* and the write an interrupt could occur which causes the scheduler to run and
* the ethernet_rx thread could be run!
# if 0
ALT_SEM_PEND(dev->semaphore, 1);# endif
/* Wait for any pending commands to complete */
do
mmu_status = IORD_ALTERA_AVALON_LAN91C111_MMUCR(dev->base_addr);
}while (mmu_status & ALTERA_AVALON_LAN91C111_MMUCR_BUSY_MSK);
/* Queue the packet */
IOWR_ALTERA_AVALON_LAN91C111_MMUCR( dev->base_addr,
ALTERA_AVALON_LAN91C111_MMUCR_ENQUEUE_MSK);# if 0
ALT_SEM_POST(dev->semaphore);# endif
return 0;
the code is altera_avalon_lan91c111.c in lwip.I write some change to test!!when i change if ((tx = alt_dma_txchan_send (txchan,buf,len*4,dma_tx,NULL)) < 0) to if ((tx = alt_dma_txchan_send (txchan,buffer1,len*4,dma_tx,NULL)) < 0) then k = IORD_32DIRECT(dev->base_addr,8);is 0x13121110;but when ((tx = alt_dma_txchan_send (txchan,buf,len*4,dma_tx,NULL)) < 0) to ((tx = alt_dma_txchan_send (txchan,buf,len*4,dma_tx,NULL)) < 0) .the k =0;why?
i think niosII ide have some bug?can you help me?or somebody change the lwip use dma operation on lan91c111?
