16 years agodisplay an image on my NEEK LCD
Hi all, I want to learn how to use my NEEK's LCD display from uclinux. For that reason, I want to use the lcd application that comes with the uclinux-dist (under user). In menu xconfig, I enab...
16 years agoHi Yasuhiro and multilane,
I am exactly trying to do the same thing. I use the HW neek_web_server_mmu and the SW with MMU (so nios2-linux-20090929.tar) Then i do menuconfig kernel/library/defaults selection [*] Default all settings (lose changes) [*] Customize Kernel Settings NiosII Configuration ---> NiosII FPGA configuration (MMU_DEFAULT) ---> (X) CUSTOM_FPGA Devices Drivers ---> Character devices ---> [*] Virtual terminal Graphics support ---> <*> Support for frame buffer devices ---> <*> Altera framebuffer support Console display driver support ---> [ ] VGA text console (NEW) < > Framebuffer Console support (NEW) The build is OK But after download on the neek it do not start : Here is the log Linux/Nios II-MMU init_bootmem_node(?,0x326, 0x0, 0x2000) free_bootmem(0x326000, 0x1cda000) reserve_bootmem(0x326000, 0x400) Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128 Kernel command line: NR_IRQS:32 PID hash table entries: 128 (order: 7, 512 bytes) Console: colour dummy device 80x25 console handover: boot [early0] -> real [tty0] And it seems not to continue to start. Nothing appears on the screen.
