15 years agoDevice tree support
I'm new to Linux/Altera but I know well Linux on another FPGA manufacturer (I will not give its name here, I don't want to be banned :D ). I don't know if community is active here or in alterawiki, so I try to post in both places. I have some issues with device tree support in the latest nios2-linux-20100621.tar. I explain it in the discussion page of the alterawiki : The page : alterawiki.com/wiki/Devicetree Then click on discussion tab Thank you for your help --------------------------- PS : I can't put full links here so here is my post on devicetree discussion : Hi, I wish to use device tree for kernel compilation. I use the latest version of nios2-linux : nios2-linux-20100621.tar that I update using ./update script This page says :
NiosII board configuration --->
(X) Generic devicetree based NiosII system
Processor type and features -->
Devicetree support
(full_path_to_your_dts) Devicetree source file
But in my nios2-linux version there is no menu called "Processor type and features" I have just :
Linux/NiosII Configuration --->
MMU support
NiosII specific compiler options --->
Devicetree support
Catch alignment trap
Kernel executes from (RAM) --->
But no place to put the Devicetree source file. Does device-tree is not supported in this version ? Do I need to take an older version ? Or maybe I do something wrong to have no "Processor type and features" configuration page... Best regards5 Replies
I have been using the "test-nios2" branch from the nos2-linux-20100621.tar
after the ./checkout cd to /nios2-linux/linux-2.6 git checkout test-nios2 cd to /nios2-linux/uClinux-dist git checkout test-nios2 make menuconfig should show: Vendors/Product Selection ---> ---Select the vendor you wish to target Vendor (Altera) ---> --- Select the Product you wish to target Altera Products (nios2) ---> You should first use defaults for kernel: --- Kernel is linux-2.6.x Libc Version (None) ---> [*] Default all settings (lose changes) [ ] Customize Kernel Settings [ ] Customize Application/Library Settings [ ] Update Default Vendor Settings save then make Vendors_HWSelect SYSPTF= nameofyour.ptf use full path then make - Altera_Forum
Thank you jkealty, but first I would like to use device-tree. Next this method is for the nommu version of the microblaze and I wish to use the MMU. Finally it does not work
I thing it is better for me to use device-tree since, as they say on alterawiki : --- Quote Start --- Nios2 linux will migrate to device tree, which will replace the hwselect of nommu or sopc_create_header_files of mmu. --- Quote End ---make: ***No rule to make target « Vendors_HWSelect ». - Altera_Forum
Ok well I auto-answer.
In fact the most important page on alterawiki (read it all carefully) is wiki/Linux_for_the_Nios_II_Processor. The trick is in this part : --- Quote Start --- Kernel development is currently taking place in the "unstable-nios2mmu" branch. It is stable despite the name. So to build a current (2.6.38 as of this writing), you need to switch to that branch for the kernel. Inside the "linux-2.6" folder, issue a "git checkout unstable-nios2mmu" command to switch your head to that branch. --- Quote End --- So to have device-tree support you need to switch the kernel to the branch unstable-nios2mmu Hope it will help someone - Altera_Forum
I really can not understand all these developers/companies. You have no idea how long it takes to figure out everything, solve all encountered errors within the massive amount of documents and posts on the internet. Is it really that hard to make one document which you can walk through without facing errors in their deliverables etc..
--- Quote Start --- I really can not understand all these developers/companies. You have no idea how long it takes to figure out everything, solve all encountered errors within the massive amount of documents and posts on the internet. Is it really that hard to make one document which you can walk through without facing errors in their deliverables etc.. --- Quote End --- Feel free to do this yourself. The wiki is open for anyone to edit. We're all working on nios2-linux on this in our spare time and to the best of my knowledge there is no funding from Altera or any other company for it.
