15 years agoDevice tree support
Hi, I'm new to Linux/Altera but I know well Linux on another FPGA manufacturer (I will not give its name here, I don't want to be banned :D ). I don't know if community is active here or i...
15 years agoI have been using the "test-nios2" branch from the nos2-linux-20100621.tar
after the ./checkout cd to /nios2-linux/linux-2.6 git checkout test-nios2 cd to /nios2-linux/uClinux-dist git checkout test-nios2 make menuconfig should show: Vendors/Product Selection ---> ---Select the vendor you wish to target Vendor (Altera) ---> --- Select the Product you wish to target Altera Products (nios2) ---> You should first use defaults for kernel: --- Kernel is linux-2.6.x Libc Version (None) ---> [*] Default all settings (lose changes) [ ] Customize Kernel Settings [ ] Customize Application/Library Settings [ ] Update Default Vendor Settings save then make Vendors_HWSelect SYSPTF= nameofyour.ptf use full path then make
