10 years agoDebugging of the FPGA portion using the HPS ARMs & Linux
Hello All, I have three SPI cores instantiated in the FPGA portion and connected to the AXI3 Lightweight Bridge (ArriaV SX device). I need to start debugging them (write to SPI cor...
10 years agoI'm confused as to what you're trying to debug. If it is custom SPI code, then you'd need SignalTap or a simulator, and use SignalTap triggering the HPS to halt on a trigger event.
If it is the Altera SPI block, then there is a kernel driver available that instantiates the Altera SPI module on the AXI bus as a spidev device, and the HPS can interface directly using the Linux spidev features. What is your goal?
