16 years agoDebugging Apps under Linux MMU
Well, I'm on to debugging apps under linux. I tried to follow (and adapt) the wiki directions for using gdb: http://www.nioswiki.com/operatingsystems/uclinux/debugapps I'm using the gdbs...
16 years agoHi,
Many thanks for the reply. These days I have been looking for the folder "nios2-wrs-linux-gnu" that you commented that I have to had. I have download and updated the tarball of 1.7GB of the nioswiki(uClinux with MMU) to be sure that I haven't erased something, and I haven't found this folder inside it. But in the web http://www.niosftp.com/pub/gnutools/ there is a folder(Maby I wrong but I think it is a cross-compiler) with the same name as you have commented . Both things the tarball and this folder have been uploaded in similar dates. Have you installed this folder after you installed the tarball ,if so do you recommend me to do it? Many Thanks
