Debugger wont connect to NIOS II hello world on Cyclone GX development board
Thank you reaching us.
For elf process failed, usually there a few things you can check. Mainly due to any mistake during the NiosII design, especially connections related to the memory where the ELF file will reside. There also a few things can check before download program to the board such as qsys configuration compilation, verilog connections between qsys generated model and board hardware. For the box "ignore mismatched system ID' and 'ignore mismatched system timestamp", can try uncheck since these checks verify that your software is compiled for the FPGA configuration that is actually loaded on the board.
- Oliver_I_Sedlacek2 years ago
Contributor
Check a gazillion things isn't really giving me a steer.
The console message is:
09:45:08 **** Incremental Build of configuration Nios II for project AcqTester ****
wsl make all
Info: Building /mnt/c/Users/olivers/Documents/sbsvn/Apogee/CO717-Cyc10/FPGA/eval_c10gx220/AcqNIOS/software/AcqTester_bsp/
make --no-print-directory -C /mnt/c/Users/olivers/Documents/sbsvn/Apogee/CO717-Cyc10/FPGA/eval_c10gx220/AcqNIOS/software/AcqTester_bsp/
[BSP build complete]
[AcqTester build complete]09:45:09 Build Finished (took 1s.157ms)
- wwanalim_intel2 years ago
Contributor
This is the log on make. There should be another log in Eclipse. We are expecting to see the log on eclipse to know either it can pass the processor reset or not.
This is the example of the log if failed the reset processor.This is the example of the log if success.
You can try use nios2-download command.
$ nios2-download -g -r <>.elf- Oliver_I_Sedlacek2 years ago
Contributor
A different console message did show but it was cleared before I could capture it.
After trying it a few more times I caught this:
Using cable "USB-BlasterII [USB-1]", device 2, instance 0x00
Pausing target processor: not responding.
Resetting and trying again: FAILED
Leaving target processor pausedWhere do I type the nios2-download command?
