16 years agoDebug user space application with MMU
I am trying to use the gdbserver as described here:
http://nioswiki.com/linux/debug_user_space At some point, this was working, but sometimes it wouldn't work and now I haven't had it working for a while. The application and gdb dies on a crash and doesn't let me debug. This isn't just this particular crash, I've had this happen with almost every crash while developing. On the server: --- Quote Start --- root:/> gdbserver localhost:9999 myprogram Process myprogram created; pid = 50 Listening on port 9999 Remote debugging from host 192.168.100.28 <program output...> Child terminated with signal = b Child terminated with signal = 0xb (SIGSEGV) GDBserver exiting root:/> --- Quote End --- On the client: --- Quote Start --- Program terminated with signal SIGSEGV, Segmentation fault. The program no longer exists. (gdb) backtrace No stack. --- Quote End --- Any advice? Also, the wiki says "we will add the gdbserver source to uclinux-dist later" -- is there any progress on this? Could the gdbserver currently in uclinux-dist work?16 Replies
This may be related to troubles debugging. I am trying to print a stack trace from within the program, but that doesn't work either. I tried with a very simple non-threaded C program:
When I build this on my PC (Ubuntu 10.10 x86_64) I get a nice stacktrace: gcc -g -rdynamic -o test_bt test_bt.c#include <stdio.h> # include <execinfo.h> # include <stdlib.h> void print_trace() { void *array; size_t size; // get void*'s for all entries on the stack size = backtrace(array, 10); // print out all the frames to stderr fprintf(stderr, "trace size %zu:\n", size); backtrace_symbols_fd(array, size, 2); exit(1); } void baz() { print_trace(); } void bar() { baz(); } void foo() { bar(); } int main(int argc, char **argv) { foo(); }
On Nios II Linux I just get this: nios2-linux-gnu-gcc -g -rdynamic -o test_bt test_bt.ctrace size 7: ./test_bt(print_trace+0x19) ./test_bt(baz+0xe) ./test_bt(bar+0xe) ./test_bt(foo+0xe) ./test_bt(main+0x19) /lib/libc.so.6(__libc_start_main+0xfe) ./test_bt
I've been trying to mess with compiler flags, but haven't found any magic so far. Any ideas?trace size 1: - Altera_Forum
--- Quote Start --- I am trying to use a core file now. I am running `nios2-linux-gnu-gdb mynios2program`, with set solib-absolute-prefix /data/nios/nios2-linux/uClinux-dist/romfs/ in .gdbinit. Then core-file mycorefile, but all I can get is:
--- Quote End --- I hit the same problem here too and traced it down to the kernel writing a faulty corefile, missing the .reg and .reg/<N> section. The cause for this was ELF_NGREG in arch/nios2/include/asm/elf.h being too small ((sizeof (struct pt_regs) / sizeof(elf_greg_t)), while ELF_CORE_COPY_REGS also writes all registers from struct switch_stack to the buffer. If ELF_NGREG is defined as in the following patch, the corefile is generated properly and can be used with nios2-linux-gnu-gdb:warning: Couldn't find general-purpose registers in core file. # 0 0x00000000 in ?? ()
I'll also apply this fix to the nios2 branch of the nios2-linux kernel git repository.-#define ELF_NGREG (sizeof (struct pt_regs) / sizeof(elf_greg_t)) +#define ELF_NGREG ((sizeof(struct pt_regs) + sizeof(struct switch_stack)) / sizeof(elf_greg_t)) - Altera_Forum
Tobias, I just saw this fix in the commit log and was surprised to see a link back to my report here because I missed your response in the thread. I will try this fix!
--- Quote Start --- This may be related to troubles debugging. I am trying to print a stack trace from within the program, but that doesn't work either. --- Quote End --- Have you get it to work, ykozlov? I couldn't print out a stacktrace in a user-level program with backtrace() / backtrace_symbols()... - Altera_Forum
--- Quote Start --- Have you get it to work, ykozlov? I couldn't print out a stacktrace in a user-level program with backtrace() / backtrace_symbols()... --- Quote End --- No, I never got that working, but tklauser's kernel fix did fix debugging using a core dump. - Altera_Forum
--- Quote Start --- No, I never got that working, but tklauser's kernel fix did fix debugging using a core dump. --- Quote End --- And I fixed the backtrace() function... or bypass it and wrote my own! stackframe.c
Makefile# define _GNU_SOURCE # include <stdio.h># include <inttypes.h># include <stdint.h># include <ucontext.h># include <dlfcn.h># include <string.h> struct frame { void *fp; // frame pointer void *ra; // return address }; void print_symbol(void *address) { Dl_info info; char library; char function; void *symbol_address; if (dladdr(address, &info) == 0) { strncpy(function, "???", sizeof(function)); strncpy(library, "???", sizeof(library)); symbol_address = 0; } else { strncpy(function, info.dli_sname, sizeof(function)); strncpy(library, info.dli_fname, sizeof(library)); symbol_address = info.dli_saddr; } printf("0x%08X %s: %s\n", (uint32_t) symbol_address, library, function); } void backtrace() { struct frame *frame; // frame = CURRENT_FRAME_POINTER __asm("mov %0,r28" : "=r"(frame)); // Last frames while (frame && frame->fp) { printf("fp = 0x%08X ra = 0x%08X\n", (uint32_t) frame->fp, (uint32_t) frame->ra); print_symbol((void *) frame->ra); frame = (struct frame *) frame->fp; } } void test3() { backtrace(); } void test2() { test3(); } void test1() { test2(); } int main(int argc, char *argv) { test1(); return 0; }
Build:CC = nios2-linux-gnu-gcc CFLAGS = -Wall -fno-omit-frame-pointer LDFLAGS = -rdynamic -ldl SOURCES = stackframe.c OBJECTS = $(SOURCES:%.c=%.o) PROGRAM = stackframe .PHONY: all clean all: $(PROGRAM) clean: rm -rf $(OBJECTS) $(PROGRAM) build: clean all $(PROGRAM): $(OBJECTS) $(CC) -o $@ $(OBJECTS) $(LDFLAGS) %.o: %.c $(CC) $(CFLAGS) -c $<
Execute:$ make nios2-linux-gnu-gcc -Wall -fno-omit-frame-pointer -c stackframe.c nios2-linux-gnu-gcc -o stackframe stackframe.o -rdynamic -ldl# stackframe fp = 0x7FE81D24 ra = 0x00001838 0x00001824 stackframe: test3 fp = 0x7FE81D2C ra = 0x00001860 0x0000184C stackframe: test2 fp = 0x7FE81D34 ra = 0x00001888 0x00001874 stackframe: test1 fp = 0x7FE81D44 ra = 0x000018B8 0x0000189C stackframe: main
