DE23-Lite + Quartus Pro 25.1 + Nios V/g: no Nios V instance, no JTAG UART
I’m working on a Terasic DE23-Lite board (Agilex 3 A3CZ135BB18AE7S) using Quartus Prime Pro 25.1, and I’m seeing a runtime debug/service issue that I have not been able to resolve.
System details:
- Board: Terasic DE23-Lite
- FPGA: Agilex 3 A3CZ135BB18AE7S
- Quartus Prime Pro: 25.1
- CPU in Platform Designer: Nios V/g
- Project started from the Terasic SDRAM_Test_NiosV / golden_top example
- USB-Blaster III is detected normally as DE23-Lite [USB-1]
What works:
- quartus_pgm programs the .sof successfully
- jtagconfig sees the board and FPGA in the JTAG chain
- Simple RTL-only hardware tests work
- CLOCK0_50-driven LED blink works
- KEY0-driven LED test works
So basic board programming, raw JTAG visibility, and simple user logic are all working.
What does not work:
- niosv-download fails with:
- "There are no devices with valid Nios V instance(s)"
- "ERROR: Failed to generate OpenOCD config file."
juart-terminal fails with:
- "There are no JTAG UARTs available which match the --device and --instance options you provided."
In System Console, the following all return nothing:
- get_service_paths device
- get_service_paths master
- get_service_paths processor
- get_service_paths jtag_debug
SignalTap also does not enumerate at runtime and reports that the device needs to be programmed / instance not found, even after compile and program.
Important points:
- The generated Platform Designer system does include Nios V/g debug-related logic and JTAG UART in the generated HDL.
- The top-level does instantiate the generated nios_system.
- The QSF includes the Qsys system.
- The fit report shows SignalTap content present in the fitted image.
So this does not look like a missing-instance-in-the-design problem. It looks more like raw JTAG chain works, but no higher-level runtime services enumerate after configuration.
One thing I found:
- In the example golden_top.v, the Nios system clock connection had a typo: .clk_clk(CLOCK1_51)instead of a real clock signal.
I corrected that and also tested CLOCK0_50. That did not resolve the no-instance / no-JTAG-UART / no-service-paths issue.
Another issue I found and fixed:
- There was a stale on-chip memory init reference to ram.hex: "Cannot find Memory Initialization File (.mif) or Hexadecimal (Intel-Format) File (.hex) C:/fpga/SDRAM_Test_NiosV/ram.hex -- setting all initial values to 0."
I removed that stale reference. It did not fix the runtime service visibility problem.
Current question: Has anyone seen a case on DE23-Lite / Agilex 3 / Quartus Pro 25.1 where the JTAG chain is visible and programming succeeds, but Nios V instances, JTAG UART, System Console service paths, and SignalTap all fail to enumerate at runtime?
I’m looking for guidance on what layer to check next:
- JTAG service / SLD runtime visibility
- Agilex 3 user-mode debug exposure
- board/project configuration settings
- Quartus 25.1-specific issue
- anything DE23-Lite-specific in the Terasic example flow
Any suggestions would be appreciated.
Steve
