19 years agode2_system_v1.5 --> tut_DE2_SDRam
Is there a bug in the sourcecode, which listed in the "tut_DE2_SDRam_vhdl.pdf"-file under ..\DE2_System_v1.5\DE2_tutorials ??? I copy and paste the code in my new project and become the f...
19 years agoNow, I have tested the "Verilog - Version" of the design and that works fine...
But i can´t find any mistake in the vhdl program code. Here is the complete source code from the vhdl tutorial, which doesn´t compile right under QuartusII 6.1:−− Inputs: SW7−0 are parallel port inputs to the Nios II system.
−− CLOCK_50 is the system clock.
−− KEY0 is the active-low system reset.
−− Outputs: LEDG7−0 are parallel port outputs from the Nios II system.
−− SDRAM ports correspond to the signals in Figure 2; their names are those
−− used in the DE2 User Manual.
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_arith.all;
USE ieee.std_logic_unsigned.all;
ENTITY lights IS
PORT ( SW : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
KEY : IN STD_LOGIC_VECTOR(0 DOWNTO 0);
CLOCK_50 : IN STD_LOGIC;
LEDG : OUT STD_LOGIC_VECTOR(7 DOWNTO 0)
DRAM_CLK, DRAM_CKE : OUT STD_LOGIC;
DRAM_ADDR : OUT STD_LOGIC_VECTOR(11 DOWNTO 0);
DRAM_BA_1, DRAM_BA_0 : BUFFER STD_LOGIC;
DRAM_CS_N, DRAM_CAS_N, DRAM_RAS_N, DRAM_WE_N : OUT STD_LOGIC;
DRAM_DQ : INOUT STD_LOGIC_VECTOR(15 DOWNTO 0);
DRAM_UDQM, DRAM_LDQM : BUFFER STD_LOGIC );
END lights;
ARCHITECTURE Structure OF lights IS
COMPONENT nios_system
PORT ( clk : IN STD_LOGIC;
reset_n : IN STD_LOGIC;
out_port_from_the_LEDs : OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
in_port_to_the_Switches : IN STD_LOGIC_VECTOR(7 DOWNTO 0)
zs_addr_from_the_sdram: OUT STD_LOGIC_VECTOR(11 DOWNTO 0);
zs_ba_from_the_sdram: BUFFER STD_LOGIC_VECTOR(1 DOWNTO 0);
zs_cas_n_from_the_sdram: OUT STD_LOGIC;
zs_cke_from_the_sdram: OUT STD_LOGIC;
zs_cs_n_from_the_sdram: OUT STD_LOGIC;
zs_dq_to_and_from_the_sdram: INOUT STD_LOGIC_VECTOR(15 DOWNTO 0);
zs_dqm_from_the_sdram: BUFFER STD_LOGIC_VECTOR(1 DOWNTO 0);
zs_ras_n_from_the_sdram: OUT STD_LOGIC;
zs_we_n_from_the_sdram: OUT STD_LOGIC );
END COMPONENT;
SIGNAL BA : STD_LOGIC_VECTOR(1 DOWNTO 0);
SIGNAL DQM : STD_LOGIC_VECTOR(1 DOWNTO 0);
BEGIN
BA <= (DRAM_BA_1 & DRAM_BA_0);
DQM <= (DRAM_UDQM & DRAM_LDQM);
−− Instantiate the Nios II system entity generated by the SOPC Builder.
NiosII: nios_system PORT MAP (CLOCK_50, KEY(0), LEDG, SW,
DRAM_ADDR, BA, DRAM_CAS_N, DRAM_CKE, DRAM_CS_N,
DRAM_DQ, DQM, DRAM_RAS_N, DRAM_WE_N );
DRAM_CLK <= CLOCK_50;
END Structure; The lines BA <= .... DQM <= ... seems to be incorrect. Has anyone a solution for me?
