15 years agoDe2-70
Hello, Can I get working Linux with MMU on DE2-70 board, if I have quartus web edition? I followed the instruction here - blog.csdn.net/pkuyjxu/archive/2010/05/24/5620897.aspx I think, that...
15 years agoYou have to be more precisely in formulating exactly what doesn't work. Without more information nobody can help you.
When you do what I have written before then you don't have a problem running uClinux on the board. As far as I know the .sof file works for an hour. When you don't want to have the limitation your Quartus has to be opened all the time you work on the board. There is also a sample for your board on the altera wiki. http://www.alterawiki.com/wiki/tryoutuclinux#for_de2-70_dev_board Urmel
