15 years agoDE2-70 Nios II problem
Hi everyone,
First of all im newbie of FPGAs Now im working with DE2-70 and my design works. but i have new problem like, ../hello_world.c: In function `test1_led': ../hello_world.c:24: error: `IOWR_ALTERA_AVALON_PIO_DATA' undeclared (first use in this function) ../hello_world.c:24: error: (Each undeclared identifier is reported only once ../hello_world.c:24: error: for each function it appears in.) ../hello_world.c:24: warning: left-hand operand of comma expression has no effect ../hello_world.c:26: error: `PIO_RED_LED_BASE' undeclared (first use in this function) ../hello_world.c:26: error: syntax error before "led_mask" ../hello_world.c:28: warning: implicit declaration of function `usleep' ../hello_world.c:30:2: warning: no newline at end of file ../hello_world.c:30: error: syntax error at end of input my code; # include "system.h" # include "altera_avalon_pio_regs.h" # include "alt_types.h" void test1_led(void){ alt_u32 led_mask=0; while(1){ // green led control // red led control (IOWR_ALTERA_AVALON_PIO_DATA, led_mask); PIO_RED_LED_BASE // toggle led led_mask ^= 0xFFFFFFFF; // sleep 0.2 second usleep(200*1000); } // while3 Replies
Does an output PIO called "pio_red_led" exist in your FPGA/SoPC Builder design? Judging from the messages, I gather that it doesn't.
Cheers, slacker - Altera_Forum
Actually, i dont know how to use variables in Nios II codes.
in my SOPC design; led and switch are my pio names so can you help me how to read value or position of switches and how can i change values of leds. - Altera_Forum
switch read:
sw_rd=IORD(SWITCH_BASE,0X00); led write: ld_wr=IOWR(LED_BASE,0X00,1); sw_rd and ld_wr are two variables and if there are two bit LED mans 2 leds) then very first LED (LED[0]) will glow as there is "1" assigned to it.
