11 years agoDE1-SoC No /dev/fpga0 device on LXDE or Ubuntu
I have been using the basic SD card image but now I need to move to using the LXDE or Ubuntu images supplied for use with the DE1-SoC. However both these images do not feature a /dev/fpga0 devi...
10 years agoI know that it's an old topic but i had the same issue and i found out something very interesting. For the new Kernel (say 4.4 for example) a "fpgamanager" was introduced and it changed the way you should send the rbf files to the fpga.
Now you need to make a devicetree overlay in order to load the rbf file, but the fpgamanager will stop the bridges and do all the work for you. I'm attempting to write a simple tutorial to the process but i'm not that good at writing an i'm not an expert on the subjec, so i'm bound to be mistaken at some things, but i know for sure that i can program de fpga. So i'll post the link here once i finish the tutorial.- GApts6 years ago
4 years in but did you write the tutorial?
