14 years agoDE0-NIOS2 clock speed limit 50MHZ
Hi, have "problem". I have DE0 dev board. When I load NIOS2 to fpga and use 50MHz from on board sorce. It works. When I try to add pll 50MHz - > works. But if I use more then 50MHz (pll ...
14 years agoHi,
how did you apply the recommendations? Maybe we can have a look at your SOPC or Qsys design ? What is the component concerned with the top failing path when you increase frequency so that the constraints are no more satisfied ? You can try a minimal design where only Nios2 is present with JTAG SysID and external or even internal RAM, that will allow you to know what Fmax your Nios2 can reach on DE0.
