10 years agoDE0_Nano_QSYS_DEMO BSP error with Quartus 15.1
I downloaded the DE0_Nano_QSYS_DEMO from the DE0-Nano_V.1.2.0_CDROM, and can't run the demo under latest Quartus (15.1) Here are the steps I followed: * Upgrade IP cores in quartus * Regenerate design in Qsys * Open the software/DE0_nano and software/DE0_nano_BSP in Nios II Eclipse * Try to generate the BSP since the IP core changed Generating BSP in eclipse gives out a pop up with this error: --- Quote Start --- Error executing 'nios2-bsp-generate-files --bsp-dir . --settings settings.bsp', unexpected return code 1. Error message: SEVERE: The device is not ready SEVERE: nios2-bsp-generate-files failed. --- Quote End --- Running it from cmd.exe, with the debug flag I get this log: --- Quote Start --- INFO: Generating BSP files...ugsdk2/bin/nios2-bsp-generate-files.exe --bsp-dir. - INFO: nios2-bsp-generate-files --bsp-dir . --settings settings.bsp --debug INFO: Initializing BSP components... FINER: Creating librarian with search path: null FINER: Creating librarian with factory search path: null FINER: Altera Environment: C:/altera_lite/15.1/nios2eds/ FINER: Altera Environment: C:/altera_lite/15.1/quartus/ FINER: Altera Environment: C:/altera_lite/15.1/quartus/sopc_builder/ FINER: Altera Environment: C:/altera_lite/15.1/quartus\bin64 FINER: --librarian-verbose FINER: >> >> >> initializing BSP Components: 3 seconds 2016.02.22.23:07:28 Conan.addPluginPath:477 (3) adding search path "C:/altera_lite/15.1/quartus/sopc_builder/bin/root_components.ipx" as "C:/altera_lite/15.1/quartus/sopc_builder/b - in/root_components.ipx" because ipx file FINER: [Progress] min: 0 FINER: [Progress] max: 1 FINER: [Progress] current: 1 FINER: [Progress] (1) searching <b>C:/altera_lite/15.1/quartus/sopc_builder/bin/root_components.ipx</b> (ipx file) FINER: [Info] Reading index <b>C:\altera_lite\15.1\quartus\sopc_builder\bin\root_components.ipx</b> FINER: [Info] <b>C:\altera_lite\15.1\quartus\sopc_builder\bin\root_components.ipx</b>: Loading now from components.ipx FINER: [Info] Reading index <b>C:\altera_lite\15.1\quartus\sopc_builder\bin\ip_component_categories.ipx</b> FINER: [Info] <b>C:\altera_lite\15.1\quartus\sopc_builder\bin\ip_component_categories.ipx</b> described 0 plugins, 0 paths, in 0,11 seconds FINER: [Info] <b>C:/altera_lite/15.1/quartus/sopc_builder/bin/ip_component_categories.ipx</b> matched 1 files in 0,13 seconds FINER: [Info] <b>C:/altera_lite/15.1/quartus/sopc_builder/bin/$$IP_PROJECTDIR/ip/**/*</b> matched 0 files in 0,00 seconds FINER: [Info] <b>C:/altera_lite/15.1/quartus/sopc_builder/bin/$$IP_PROJECTDIR/*</b> matched 0 files in 0,00 seconds FINER: [Info] <b>C:/altera_lite/15.1/quartus/sopc_builder/bin/$$IP_PROJECTDIR/*/*</b> matched 0 files in 0,00 seconds FINER: [Info] <b>C:/Users/louis/.altera.quartus/ip/15.1/**/*</b> matched 0 files in 0,00 seconds FINER: >> >> >> initializing BSP Components: 6 seconds FINER: [Info] Reading index <b>C:\altera_lite\15.1\ip\altera\altera_components.ipx</b> FINER: [Info] <b>C:\altera_lite\15.1\ip\altera\altera_components.ipx</b> described 1698 plugins, 0 paths, in 3,99 seconds FINER: [Info] <b>C:/altera_lite/15.1/ip/**/*</b> matched 134 files in 3,99 seconds FINER: [Info] Reading index <b>C:\altera_lite\15.1\quartus\sopc_builder\builtin.ipx</b> FINER: [Info] <b>C:\altera_lite\15.1\quartus\sopc_builder\builtin.ipx</b> described 82 plugins, 0 paths, in 0,03 seconds FINER: [Info] <b>C:/altera_lite/15.1/quartus/sopc_builder/**/*</b> matched 8 files in 0,03 seconds FINER: [Info] Reading index <b>C:\altera_lite\15.1\quartus\common\librarian\factories\index.ipx</b> FINER: [Info] <b>C:\altera_lite\15.1\quartus\common\librarian\factories\index.ipx</b> described 151 plugins, 0 paths, in 0,03 seconds FINER: [Info] <b>C:/altera_lite/15.1/quartus/common/librarian/factories/**/*</b> matched 4 files in 0,05 seconds FINER: [Info] <b>C:/altera_lite/15.1/quartus/sopc_builder/bin/$IP_IPX_PATH</b> matched 1 files in 0,00 seconds FINER: [Info] <b>C:\altera_lite\15.1\quartus\sopc_builder\bin\root_components.ipx</b> described 0 plugins, 9 paths, in 4,24 seconds FINER: [Info] <b>C:/altera_lite/15.1/quartus/sopc_builder/bin/root_components.ipx</b> matched 1 files in 4,24 seconds FINER: >> >> >> initializing BSP Components: 9 seconds FINER: >> >> >> initializing BSP Components: 12 seconds FINER: >> >> >> initializing BSP Components: 15 seconds FINER: >> >> >> initializing BSP Components: 18 seconds FINER: [Progress] min: 0 FINER: [Progress] max: 2 FINER: [Progress] current: 1 FINER: [Progress] current: 2 FINER: [Progress] (1870) searching <b>C:/altera_lite/15.1/nios2eds/components/components.ipx</b> (Nios II Software Tcl Components) FINER: [Info] Reading index <b>C:\altera_lite\15.1\nios2eds\components\components.ipx</b> FINER: [Info] <b>C:\altera_lite\15.1\nios2eds\components\components.ipx</b> described 18 plugins, 0 paths, in 0,00 seconds FINER: [Info] <b>C:/altera_lite/15.1/nios2eds/components/components.ipx</b> matched 1 files in 0,00 seconds INFO: Finished initializing BSP components. Total time taken = 7 seconds FINER: Searching for BSP components of subtype: IBaseSoftwareElement category: os_software_element FINER: Adding catalog card: Altera HAL FINER: Adding catalog card: Micrium MicroC/OS-II FINER: >> >> >> searching BSP components: 3 seconds FINER: Finished searching for BSP components. Total time taken = 2 seconds FINER: Executing Tcl Script: "C:\altera_lite\15.1\nios2eds\components\altera_hal\altera_hal_sw.tcl" FINER: Finished executing Tcl Script. FINER: Adding Tcl initialized 'Altera HAL' (C:\altera_lite\15.1\nios2eds\components\altera_hal\altera_hal_sw.tcl) os software to catalog FINER: BSP type found: Altera HAL(hal - 15.1 - [os_software_element]) FINER: Executing Tcl Script: "C:\altera_lite\15.1\nios2eds\components\micrium_uc_osii\micrium_ucosii_sw.tcl" FINER: Finished executing Tcl Script. FINER: Adding Tcl initialized 'Micrium MicroC/OS-II' (C:\altera_lite\15.1\nios2eds\components\micrium_uc_osii\micrium_ucosii_sw.tcl) os software to catalog FINER: BSP type found: Micrium MicroC/OS-II(ucosii - 15.1 - [os_software_element]) SEVERE: The device is not ready java.io.IOException: The device is not ready at java.io.WinNTFileSystem.canonicalize0(Native Method) at java.io.WinNTFileSystem.canonicalize(Unknown Source) at java.io.File.getCanonicalPath(Unknown Source) at java.io.File.getCanonicalFile(Unknown Source) at com.altera.embeddedsw.bsp.utils.LibraryUtils.addSopcProjectPathToLibrarian(LibraryUtils.java:123) at com.altera.embeddedsw.bsp.BspFactory.create(BspFactory.java:286) at com.altera.embeddedsw.bsp.BspFactory.open(BspFactory.java:165) at com.altera.embeddedsw.commandline.bsp.BspGenerateFilesCommand.execute(BspGenerateFilesCommand.java:86) at com.altera.embeddedsw.utilities.commandline.AbstractBuildCommandLine.executeCommand(AbstractBuildCommandLine.java:150) at com.altera.embeddedsw.commandline.bsp.BspGenerateFilesCommand.main(BspGenerateFilesCommand.java:118) --- Quote End --- I don't really understand what's going on and can't pinpoint the error. What can I do to fix this? Regards1 Reply
FINER: Adding Tcl initialized 'Micrium MicroC/OS-II' (C:\altera_lite\15.1\nios2eds\components\micrium_u c_osii\micrium_ucosii_sw.tcl) os software to catalog
FINER: BSP type found: Micrium MicroC/OS-II(ucosii - 15.1 - [os_software_element]) SEVERE: The device is not ready Looks like you are trying to configure the BSP to include the Micrium RTOS. Might be a license issue. Try generating the BSP without the MicroC/OS-II. I doubt you need an OS on your softcore processor.
