21 years agoDDR vs. SDR RAM...
Anyone know if DDR Ram will fare better with the NiosII data master than SDRAM? After Dirk figured out it takes a whopping 12 clocks @50MHz (~240ns) per SDRAM read when not using the dma, we re...
21 years agoHi Jesse,
I'm still confused as to why the timing diagrams in the SDRAM datasheet show that we can get data in a fraction of of the time it actually takes. Once the chipselect and address are on the address bus its only a clock or three before the sdram chip has the data ready on the data bus. So where are the other 9-11 clocks consumed? Is there a 6+ clock delay for addresses eminating from the Nios onto the Avalon bus? Or are there long delays delivering the data back into the Nios? It wasn't that long ago I was writing code on PC's running around 100 MHz with same PC100 memory and random memory reads were 50-60ns if I remember correctly. What gives? Thanks, Ken
