20 years agoDDR SDRAM vs SSRAM
I've develop a project with 3 Nios II processors and 4 on-chip memories and mutexes. And I'm using a Development kit Cyclone II and Quartus and Nios IDE 5.0. Often in my code the processors n...
20 years agoHi, Wolfang.
--- Quote Start --- originally posted by wpaulus@Aug 17 2006, 07:03 AM just a guess: the nios/f has data cache.if another avalon master changes the value of your flag in memory, the nios/f processor doesn't notice, because it loads the value from the cache.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17667)
--- quote end ---
--- Quote End --- Good point! I've thought that declaring my on-chip memories instances as volatile, this problem couldn't happen. However, the problem is still deeper. I had already also tried to run the application under Nios/f processor without data cache (0Kb). The problem remained. --- Quote Start --- originally posted by wpaulus@Aug 17 2006, 07:03 AM if you load the values by using the 'ldwio' opcode, you read the value directly from memory.
--- quote end ---
--- Quote End --- I've enjoyed your suggestion too much. Can you send me a simple example of how can I use that opcode. I don't know it yet. Or, maybe, the name of the header file where are declaring the routines I need to use. With this I suppose I can take more informations in Nios II Software Handbook. --- Quote Start --- originally posted by wpaulus@Aug 17 2006, 07:03 AM and depending on your optimization level, the value isn't read at all from memory, only a value in a processor register is checked. you can cirumvent this by adding 'volatile' to your variable declaration.
--- quote end ---
--- Quote End --- I've checked my code again and, in fact, I used 'volatile' in all the declaration of the 4 shared memories. --- Quote Start --- originally posted by wpaulus@Aug 17 2006, 07:03 AM also, isn't there a hardware mutex component that synchorinzes access to memory between different processors?
--- quote end ---
--- Quote End --- Yes. Actually, each memory has a mutex protecting it. This question remembers me another doubt. What, in fact, happens when a processor try to verify the value of a variable, like in (***)? I've noticed, at least in my projects, that checking this before or after lock a mutex makes no difference. Is there no conflit among processor when trying to verify memory on this way? Thank you to much, Wolfang. We had a good discussion here. I'll be waiting new suggestions from Nios Community. Regards, Mendonça.
